allensteiner »
https://forums.nicoclub.com/allensteiner-u79163.html
Mon May 19, 2008 6:42 pm
i had a hair size crack on the top of the radiator, when i revved the eng up to about 3k rpm or over the coolant would shoot out of it. so i temporarily patched it up with epoxy and it doesn't leak for now.
the prob i have is the coolant smell when the engine warms up. i can't really locate it though. sometimes i think it's from inside the car (busted heater core? the heater works fine) or somewhere under the hood. i even thought i might have a cracked block or a freezer plug that's leaking, but there's no coolant loss.
any suggestions? i did a pressure check of the system and it was fine.
