ediekrager »
https://forums.nicoclub.com/ediekrager-u267554.html
Sat Aug 27, 2016 1:07 pm
I own a 2014 Pathfinder SL (and new to this forum). 35k miles. Even since we took delivery, there has been a coolant smell outside of the cabin after driving. Ironically, I don't notice the smell nearly as much when I open the hood. The level in the overflow tank has slowly, but steadily decreased over time. It got to the point where it would barely reach the minimum level marking AFTER it had warmed up. I've had it in twice to the Walser Nissan dealer and they haven't found anything wrong. They said they ran a pressure test which came back fine. They did top off the coolant, which does prove my point that it had been losing a bit of coolant over time. The service manager (after the service advisor went to get him) said that a bit of evaporation was normal. I said that was BS and you shouldn't have to top off the coolant in a vehicle still under warranty, nor should you be able to smell it.
Two questions. First, and foremost, has anyone else had this problem? Second, can I write to Nissan (of North America?) and get some type of paper trail started or elevate this issue somehow?
