Coolant sensor>>No start?
clever240sx
Car: Nissan 240sx
I can get the car started if i leave it sit for a few hours but after i let it warm up and shut it off then try and restart it, it wont fire. Its a 89' 240 and also my coolant gauge isnt working. What do you think the problem is and how to fix it?
Modified by clever240sx at 7:59 PM 3/9/2009
clever240sx
Car: Nissan 240sx
Or im still kinda thinking its the EGI Pump relay. I found the ground(i think) for that relay and snipped the wire and and made a different ground and now i can at least get it started but then after i get it started & warmed up and shut it off and try to restart i got nothing???????????
clever240sx
Car: Nissan 240sx
Ok its def not the coolant bs
I now ran a jumper wire in the relay and it will start but run very bad and die
ANYONE HAVE ANY SUGGESTIONS??????????????
Stripes
Car: hatch, coupe
That seems very odd. I had to re ground that wire on my EGI relay as well because I wasn't getting power to my fuel pump after I did my swap (s14sr>s13). Was the wire you snipped black and pink?I dunno why that would cause your car to only want to start sometimes though.... hmmmmmm.. I is curious
clever240sx
Car: Nissan 240sx
Yep i regrounded the black/pink wire. And i have a jumper wire in teh relay and it runs like crap now....
clever240sx
Car: Nissan 240sx
Anyone out there have an idea??????????????????????????????
