Coolant Sensor Installs
MrIllegalX
Car: 89 240sx - SR20'd
I have to install a new thermal sender and coolant sensor. (The sensors that send the info. to the gauge cluster and the ecu) Where are these sensors located and how do I uninstall and install them?
I think the thermal one if located next to the TB, but I'm not sure. Oh, and these are KA24DE OEM sensors being used on a SR20DET.
s13sr20chris
on rwd sr20det you will find them between throttle body and valve cover. down just a little. they will be sitting in the intake manifold if i remember correctly. easy fix. just put a sock on em and the come right out.
