if you rad is cracked most likely it is causing your issue go hunt down a new to you one that is in good condition or you could repair it if it isn't to bad.IMHO i would get the replacementShabbernigdo wrote:Im having the exact same problem right now. I just changed out the thermostat and while i was bleeding the air out of the seystem i noticed i have about an inch long crack in the plastc upper radiator part right next to the upper radiator hose so i cant really tell right now if the thermostat or the crack is the cause of the overheating / boilover problem.
OMG i loves me a good run on sentence.
what you guys are failing to see is the fact that the crack in the radiator is allowing air into his coolant system so even if he replaces all the other pieces you are recomending he will not be able to properly bleed his systemyoungun21a wrote:or run it with out a thermostat, and see if it get hot,if it don't not they u have air in the system and your thermostat is no good.
Also remember that the system operates under pressure. With a crack you will not be able to generate system pressure and the boiling point of the coolant is lowered to the same as if you were heating a pot of water on a stove.240life wrote:what you guys are failing to see is the fact that the crack in the radiator is allowing air into his coolant system so even if he replaces all the other pieces you are recomending he will not be able to properly bleed his system
On a side note: your thermostat and your fan work completely independently of each other. The thermostat they are talking about is the one that is actually in the coolant system and is controlled mechanically, not electrically.s13supreme wrote:correct me if im wrong but my thermostat is working because my fan is working
s13supreme wrote:i checked all of that...
hmmm, didn't sound like you did from your previous response.s13supreme wrote:you guys taught me a lot. but for now i cant do anything...
