I am toying with the idea of leaving that mix in even thru the winter as its still good well into the minus 20's and it hardly ever gets that cold here even at night.
Also the mix doesn't immedately freeze as soon as the temp drops below it's freezing point, it can take many many hours for the coolant to assume the out side temp even approxiamtely.
And it takes the loss of A LOT of joules for water at 0C to turn from liquid to solid.
So even a thin mix is pretty safe in most climates that dont have a combination of very low temps and hi winds to accelerate the cooling out process.
Having said all that I will probably get nevous come December and switch to a 57-60% dist water to 1 bottle redline wetter water and rest antifrezze.
Fred...
