coolant problems
jfreeman
Car: 91 240sx
my car is losing coolant and i have no leaks??????
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
Did you pressurise your cooling system with a cooling system pressure tester, or simply check for leaks while the vehicle was running? Do you have white smoke coming from your tailpipe?The more info you give will result in the best response possible. What kind of diagnosis have you done to this point?
jfreeman
Car: 91 240sx
i had just replaced my thermo and all was good and then went to start one day and heat gauge did not drop and when i checked it it was almost a gallon low then i proceeded to fill it back up and after i did it was all good for another week no leaks no moisture in the oil and no white smoke from the back
thatdudety
Car: 1991 dodge stealth
gotta be leaking somewhere.. what ahbe the radiator hoses? dryrotted or anything? or maybe the tank seals are bad. check around there too.
jfreeman
Car: 91 240sx
thanx guys i found it it was a leak a verrrrry small one too its barely leaking from the thermo housing
S14-KOUKI-MONSTER
No problem.
thatdudety
np
