nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Wed Mar 22, 2017 6:29 am
Was it already warm when you removed the bleeder cap? If so, then coolant would shoot out no matter what even if the radiator cap was already off. The coolant will displace most of the air when the system is pressurized. Some of the air can even dissolve into the coolant. That is why typically people remove the rad cap and bleeder cap before starting the engine. As the engine warms up, it pushes the air out. If the engine is fully warm, then the pressure is so great that it will shoot out the bleeder hole and even the radiator cap sometimes. I have bled the air out of my system on my 04 Pathfinder after replacing the thermostat and I used the same procedure, but I removed the cap and bleeder cap before starting the engine. I also ran a piece of aquarium hose from the bleeder cap down to a clean milk jug with fresh water in it beside the car so when the coolant came out it ran into the jug rather than into my engine bay and the driveway. The water let me watch it bubble the air out which it did for a while before coolant finally came out.
You haven't overheated yet which is good news. The bad news is, you are probably looking at a failing head gasket. I recently had this same issue with my Volvo. Coolant was disappearing and there was no reason for it. I ignored it and eventually the car developed a slight miss at cold starts. I used one of the hydrocarbon tests and it passed. I checked compression on all 5 cylinders (yes 5) and it was within spec, but one was lower than the rest. Finally, a little oil showed up in the coolant after I drove it pretty hard during an emergency. I put dye in the coolant, ran the car til warm, then let it cool. I pulled the spark plugs and shone a UV light into the cylinders. I found coolant in, you guessed it, the cylinder that had lower compression. That explained my misfire and confirmed my head gasket leak. I was still within specifications for cylinder compression on that vehicle, but had a head gasket leak. The Volvo is currently in the shop being torn down for the head gasket.
Those exhaust gas in coolant leak test kits really only work if there is a large leak pushing a large volume of CO2 into the cooling system. They are used more to confirm that the leak is pushing gas into the coolant rather than to decide whether or not there is a leak at all. A compression test is a better bet, but like with my Volvo, not always 100%. A leak down test is probably the best test and worth the $40 or so for it to decide once and for all. If you have any mixing of fluids at all then do not drive the car.
You can have it checked by a shop or dye the coolant yourself. Check all places that it could leak as well to rule that out. You can even borrow leak down test kits that you can use to pressurize your cooling system with it cold (and I mean overnight cold) and a gauge will read the pressure and measure any leakage. I hope it is not using the coolant internally, but there is a good chance since there is no sign of obvious leakage and you are losing a full gallon in 2100 miles.
Have you noticed any smell of coolant after driving? If so then that is a good indication of an external leak. Don't inhale it directly, but fan some of the exhaust into your face and check for a sweet smell on a cold start. That is a good indication that it is using coolant internally.
Edit:
Also welcome to NICO! Not many of us still here with R50 Pathfinder and Qx4's, but hopefully we can help you out!
