Coolant lines.
Nismo_Touge_Monster
Car: 1991 Nissan 240SX HB
Hey everyone. I need some help with my coolant lines on my S14 SR. I just dropped in my SR into my S13 yesterday, and trying to hook everything up, and set up for custom wiring, and charge pipe mock up. Before I do that, I need to know which coolant lines aren't necessary, since I deleted my heat. This is my summer car, so just a blower motor did/will do the job when it rains, etc. Thanks in advance!
Razi
Car: Moo
You can remove/loop the coolant lines that go to your throttle body if you want.
I'd keep the heater though, it's a good backup for when you overheat. I see no reason to remove them.
Nismo_Touge_Monster
Razi wrote:You can remove/loop the coolant lines that go to your throttle body if you want.
Thanks thanks. Yeah, I know its a good backup, but my core was leaking and completely clogged with what seemed like dirt? , and I didnt wanna put another in. Seems like they build the entire car around the core lol. Would your car still overheat if it's built properly though?
Razi
Car: Moo
It shouldn't, but it's a good backup to have.
You can probably find a replacement at the junkyard for cheap. But those things are a pain to get to!
