Postby
starkos14 »
https://forums.nicoclub.com/starkos14-u26133.htmlSat Jul 21, 2007 4:44 am
im going insane. i replaced like every coolant hose under the intake mani and every 2 weeks i blow another coolant hose. i replaced my rad cap recently and im sure its functioning fine. im so pissed and no idea how to stop the problem
Postby
T-rev »
https://forums.nicoclub.com/t-rev-u68340.htmlSat Jul 21, 2007 6:18 am
you're not running anything weird like an electric water pump are you? I would check your rad lines, maybe the outlet from your motor (inlet to your rad) low pressure side anyways, may be plugged up or something. This would end up functioning like a fpr, back up the system and give you crazy high water pressure.
