NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Fri Apr 08, 2005 2:50 am
yep, those back of the manifold/head hoses are really hard to get to with the motor in the car... (CHANGE THE HOSES BEFORE YOU SWAP!!! lol)
but IIRC you have an importedl silvia right? Anyways, no USDM car will use the same hoses back there (pulsar fwd CA18DE aren't the same) so just pull off the busted one and take it to the autoparts store and have them match it to something. They'll most likely give you a piece of straight hose the right diameter and you can cut it to size and bend it to fit in there.
I had a small under the manifold coolant hose burst on me the other day, and it was hell replacing it... Just keep at it! Those hose clamps suck.
Sean
