Coolant line connections
Dirty Dee
Car: 1989 240sx
Hi. I'm in the process of finishing up vacuum and coolant lines, but I am missing some lines and wanted to verify how some of them hook up.
for the throttle body, does it go like so:
and at the back of the block, do I unhook the blue line, and make a fitting to resemble the pink "h" to go to the turbo lines? And lastly, the red and green highlighted lines are for the heater correct?
thanks for any help
Dirty Dee
Car: 1989 240sx
Anyone?
robbie2883
Car: 1998 RB25 Kouki
you don't really need the lines running through the throttle body. they are more of an emissions setup and will actually heat up your air charge.
as for the other stuff...yes...looks like you have it right except the pink line. the large diameter goes to heater core and the turbo line tee's off of it
