h.240 »
https://forums.nicoclub.com/h-240-u64149.html
Tue Apr 01, 2008 5:41 am
I'm doubting you can buy a replacement for that peice of pipe, it is most likely pressed into the aluminum very tightly. Try taking off your manifold and see if you can get it welded. If it is infact steel it shouldn't be too hard to weld it just needs to be cleaned well. You could also try to find another intake manifold to replace it. Just make sure it doesn't have the same problems, lol.
