Coolant Leaking from the Rear of the Block
evil_panda
Car: 94' Infiniti Q45
Hey guys, just like the the title says. I have a coolant leak and it on the rear of the block. I felt back there and its doesn't seem like its the heater hoses. Does anyone have any suggestions? I was told it was a Blown Head Gasket. But it doesnt have the symptoms of having a blown gasket i.e. (milky oil, water from exhaust, white smoke). Can anyone Help!!! PLEASE!
qship96
Car: 1996 Infiniti Q45
we can only guess, you must get an inspection mirror and identify exactly where the leak originates...could be a heater hose, under plenum water hose, seeping freeze plug, or a real gasket issue.....no way to tell without looking.
Q451990
Always possible that you have a leak under the plenum and it's blowing back too... although it would have to be quite a leak... lots of places to trap fluid under there. You can get a coolant system pressurizer as a loaner tool at Advance Auto or places like that that helps find these things more easily.
Heath
evil_panda
thanks guys!! I gotta figure this leak out ASAP!
evil_panda
Problem Fixed Q451990 was right it was a cut hose under the plenum. Thanks guys!
Q451990
:dblthumb:
