alright...revved the car to around 5000 after it was all warmed up and everything..got outta the car after i shut it off and stepped back to take a look (just because) and noticed a puddle of antifreeze/coolant pooling on the ground just underneath the oil pan...its dripping at a fairly steady rate so i pop the hood..look under and its sprayed a lil bit on the plug coil and along the front of the motor and its steamin a lil bit...start the car back up...drippings stops...does not spray or anything...turn car off and the dripping starts back up...its like running bown the front of engine somewhere but cannot see it because one of thepullehys is n the way..but its between the inlet and outlet coolant hoses
please help!89 240sx FB 5speed SOHC
