mentordrift »
https://forums.nicoclub.com/mentordrift-u39083.html
Thu May 08, 2008 2:46 pm
So, I fixed and replaced my radiator on my S1 RB25 with an aftermarket 2 row unit, and everything was running good until we got it back from a quick test drive.
When parked, the engine spewed most of it's coolant all over the driveway. I thought that I had a leaking radiator hose, but upon closer inspection, the engine is leaking coolant from underneath the intake manifold. It leaked enough to create a 2 foot radiused puddle under the car in a matter of minutes.
Is this a common problem? Besides the fact that I know that it is coming from SOMEWHERE under the intake manifold, I believe that it is leaking from near the small gray cylinder looking part that is almost above the oil filter. This has some hoses running to it, but I am not sure.
If this is the area, what is the easiest way to get to this problem spot? I'm trying to NOT remove the intake manifold, but if that's necessary - so be it.
Can anyone confirm that there are coolant hoses underneath the intake manifold, because my guess is the guy I had help me clean the underside of it forgot a spring clip down there, and it's leaking because of that. If not, I have no idea where to buy hoses.
