180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Jul 28, 2004 9:26 am
When you fill the coolant, look for the little yellow sticker that says "do not open when hot" somewhere around your coolant lines. You'll need to open that and fill your cooling system via the radiator and cap that bolt when coolant starts to flow out of there. Then focus on your radiator and fill. Cap the radiator when it's at the top, squeeze your radiator hoses and uncap then refill. Repeat until you've got as much coolant in there as possible. Then start your car, squeeze your radiator hose, after a minute or so, turn off the motor, let cool and refill.
a blown headgasket you'll see if you drain the oil or if you also check down your oil filler. You should be able to stick your finger in there with the motor OFF and have a check at the oil and see if it looks like coffee. Coffee colored is bad and you'll be screwed.
