nickelghandi »
https://forums.nicoclub.com/nickelghandi-u215217.html
Thu May 04, 2017 4:59 am
Blindaviator, I would say that it is a hose that leaks under certain conditions, but he said it leaks to a certain level even if it is not driven. Assuming that also means not running, then crossover pipe is also likely. I think you are right on the money with your two guesses.
He mentioned that he plugged all lines which made me think hard lines rather than hoses.
lngbrd50
While diagnosing, it might be better (cheaper) to use distilled water instead of coolant. If you have the tools to pressurize the system without running the engine then that is the way to go. If you have to run the engine to build pressure, then you should use coolant because distilled water can boil more easily.
Also, if using coolant instead of water, you could always dye the system with some UV coolant dye and then run the car just up to OT and then presssurize all the way and check for signs with a UV light or blacklight. That is my preferred way to find leaks. Even if it lands on something hot, the dye manages to stay behind.
