Coolant Leak
TuRbOS13
Car: 91 S13 Coupe KaT
Its a Turboed KA. I run no thermostat so my engine doesnt overheat. After a decent drive for maybe like 10 minutes I look under the hood at the radiator cap and there is some coolant spilled around it. If I go for a shorter drive for like 5 mins it only leaks out sometimes. I don't think its overheating cuz the engine feels warm-regular temp and the temp gauge never goes higher than medium. Any feedback is appreciated.
Cone Junky
Car: S13 fastback
BMW e46 328i
There is a chance your temp gauge is incorrect, but a greater chance you have a blown headgasket pressurizing your cooling system
TuRbOS13
I have no symptoms of a blown head gasket. Smooth idle and no sweet smell, like coolant burning. It doesnt smoke white at all.
Cone Junky
Car: S13 fastback
BMW e46 328i
Just because there isn't coolant leaking into the combustion chamber doesn't mean there isn't combustion gasses/pressure going into your coolant. Think about it...cooling system pressure is usually around 15-20 psi and engine compression is about 150-180 PSI. Which way do you think pressure is going to move first?
You need a block tester or an exhaust gas sniffer to check for CO in the cooling system.
Things like this happen when you boost an engine that wasn't meant to be boosted.
TuRbOS13
Ok i'll look into that. What are some other symptoms that I should be encountering if I have that headgasket problem?
