cleopp3 wrote:ya def from the front of the block seems to drip into the pulleys and directly under the oil pan.
Mine went out in like April or May of this year and that's exactly where it was dripping on. The water pump is made to do this so that you have some time to change it before it fails catastrophically.
The good news is that it's freaking easy to change.Also if you replaced your radiator and have to replace your WP if I were you I'd just buy as many radiator hoses that you haven't replaced and do them all at the same time. After replace 1 thing in the cooling system the next oldest thing just breaks so while your in there (with alot of coolant already drained) you might as well just replace as much as possible so you don't have to do this again a month down the road.
For S13Take out your fan shroud, fan , fan clutch.Line up the hole in your power steering pump up with the bolt that bolts the PS pump to the engine mount. Unbolt that and move the PS pump over enough to take off the belt.
Unbolt the bolts around the water pump and knock if off with a piece of wood or rubber malled (or a metal hammer if your like me and are sure you got all the bolts off and don't care about the old WP.)
Put a tiny bit of RTV blue gasket maker on both sides of the gasket that come with your WP (or don't put any if you wish) and reverse all the steps to put your water pump back on..
Bad news... Well your out like $40 and maybe a hours worth of time and can't drive for a few hours after that if you put RTV on your junk (by junk I mean WP gasket.)
Modified by modulation at 10:48 AM 8/30/2008
