NiX »
https://forums.nicoclub.com/nix-u102894.html
Tue Aug 05, 2008 6:43 am
Trying to diagnose several problems, slowly getting back to a smooth running car.
About a month ago, the car's temp gauge shot up, so I turned the heater on and got it to go back down, so I drove it back home. I checked out the car and did a spot check and it sounded 'normal' So I drove it again, less then a mile later it heated up again. I replaced the thermostat and the problem went away. Since then the car leaves little puddles of coolant while sitting (after driving 7 miles in the morning), but the over flow and radiator remain full. I replaced the belts and water pump yesterday along with the idler/tension pulley. Today I notice it is still leaking but the puddles are gradually getting smaller. I can twist bolts but I have a hard time dianosing problems, what does this sound like?
2nd, when the Air is blowing, I hear a metal sharp but faint sound on the right side of the car. Sounds like it is coming from the vents. I turn the air off and it goes away right away. Turn it back on and the sound is back. With AC on or Off, hot or cold. It doesn't do it all the time either... Any idea about this one?
Thanks a lot for this site. I'm an ex-mr2 owner that did a lot of work on that, but since i got married with kids, and then deployed for 7+ mo, finally trying to get this car back into shape!
