slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Sun Jun 12, 2005 11:39 am
I have a bad leak on the pass. side of the engine... I can't tell from where though. It doesn't leak at all with the engine off, with the engine idling it barely drips, and when you rev it it spews quite a bit of coolant out. I checked both heater hoses and replaced a section of one of them that looked questionable, but the leak stayed. I ran my hand down the length of rubber tubing that goes from the block to the oil cooler while revving the engine and could not feel any leak there, but the whole time I was doing that, coolant was still sloshing onto the ground below the engine. When I lay on my back uncer the car I can see the stream running over the starter motor, which I believe is above the "freeze" plugs. I'm running out of solutions unless the headgasket has sprung a leak and is leaking coolant... but I can't see where it is leaking from at all. Its really bothering me and its leaking bad enough that I've stopped driving the car until I can get it taken care of. any suggestions?
I guess if no one has had anything familiar I'll have to break out the FSM and see where all the coolant lines run and see which ones might be in the area where its leaking from (above starter motor), maybe the turbo coolant lines? I'd like to take the intake manifold off to see where its leaking better, but since it only leaks when it runs I wouldn't be able to tell unless the crack or slit was large enough for me to see, and if it was a blown headgasket I wouldn't be able to tell at all... there is no coolant in the oil or oil in the coolant by the way.
