Motor: Redtop SR20DET
I have some coolant leaking from the location highlighted in the image I attached. My question is, is this solved by a simple gasket/o-ring replacement, or is this something else. Its leaking from where that piece bolts onto the motor. If this is a gasket fix, will a gasket from a transverse SR20DE work?
Any help is appreciated.
Regards,floh
