Ditto on the gaskets.Towncivilian wrote: Yes, you should replace the various UIM/LIM gaskets as well as the throttle body gasket. If you want a list of all the OEM part numbers for gaskets, WCV and its gaskets, provide your VIN here.
It is a lot of work, but it's more tedious than time consuming. It's certainly doable, just make sure you keep track of bolts and nuts and print out the relevant pages of the FSM for torque specs for reassembly.
While you have everything apart, you should apply red threadlocker to the power valve screws to ensure they don't fall out (unless you have a manual transmission in which case you have no power valve screws).
Yes, I bought the gaskets (dealership).yngw13 wrote:Hey Buzzman,
What tools were required for this job?
Did you end up buying gaskets too?
Towncivilian wrote:Intake manifold correctors? I've seen that typo in the FSM before. They are collectors. Yes, you should replace the various UIM/LIM gaskets as well as the throttle body gasket. If you want a list of all the OEM part numbers for gaskets, WCV and its gaskets, provide your VIN here.
attofarad wrote:Towncivilian wrote:Intake manifold correctors? I've seen that typo in the FSM before. They are collectors. Yes, you should replace the various UIM/LIM gaskets as well as the throttle body gasket. If you want a list of all the OEM part numbers for gaskets, WCV and its gaskets, provide your VIN here.
My wife has the same problem (which means I have it)
JNRDR09Y61W217485
It's the QX4, put parts should be the same.
Gary
