landtodd »
https://forums.nicoclub.com/landtodd-u258.html
Fri Dec 27, 2002 10:33 am
In my backwoods state capital, I don't trust anyone to work on this rare (oddball?) car either. I'm on my own. T3 in Atlanta is the only service organization I feel I might trust to do anything right the first time.
If there's no coolant "in the valley" (there shouldn't be *any*) I suppose we need to return to what could be leaking at the back of the motor. Freeze plugs? There was a thread about that a year or so ago.
When my under-plenum hoses were leaking, the car gave me two heat-cool cycles before -gurgle- I had to add coolant. Now that I've done it, it's a luxury to not have to crack the hood 4x a week.
Plenum removal is labor intensive. Since it's your first time, it may take more than 8 hours round-trip. Go ahead and cut hoses that hold you back -- it will save your sanity and your back. Even DIY, it's possibly expensive, since there's plenty to examine while you have the plenum off, particularly the knock sensors, likely casualties if you're having temp problems. And just as important, the knock-sensor wiring harness, which can corrode if it's been in a damp under-hood environment.
When I bought mine, the "under plenum kit" from Scottsdale did not include the most likely leaky hoses -- the "coolant bypass" hoses. Once you have it off, there's always something else.
A light-duty torque wrench is the only "special" tool you need.
Oh, there's a bracket connected to the driver's side rear of the plenum. The wiring from the driver's side oxygen sensor is tie-wrapped to it. You'll think you have everything disconnected, but then you end up tugging on that poor oxygen-sensor wiring for all it's worth. My oxygen sensors were old, and I assumed I damaged this one, so I went ahead and replaced them both. It was time anyway. See what I mean?
Be aware that if you order oxygen sensors from sparkplug.com, they take three to four weeks. Reliable, but slow. If you have time to plan ahead, the price is worth the wait. They saved me at least $200 for NGK.
