Coolant Leak I30
qewen
Car: Infinity I30 2000
Hi everyone--I just joined and this is my first posting. I have a coolant leak on my 2000 I30(110K) . It looks like it is coming from the area between the engine block and the alternator/AC Compressor . Before I replace the water pump I just wanted to ask if there is anything else that could be leaking in that same area (freeze plug , thermo switch ) ?
sleepyS14
Car: 1997 Nissan 240SX 2JZ30DETT
2006 SAAB 9-2X AERO
did you check all your hoses for leaks ? why replace the pump off the bat?
welcome to Nico btw
maxhopper
Car: 02 Maxima SE 6spd
I would check to make sure its not the thermostat neck leaking and running down. The water pump is a major pain to replace.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
BAR NONE, leaks are the toughest thing for a shop to fix, mostlybecause they dont want to take the time to do it and want to sell parts.
1) Get some kind of alchohol bases cleaner (throttle body cleaneror Electromotive cleaner) and a lot of rags and clean up the areain question thoughly) before even looking for the leak. Do this oneday and look for the leak the next.
Come back 4 hours later with a dry rag and rewipe. The old throttle bodycleaner tends to "hang on" to the steel you sprayed on easier than youthink.
2)Clean your driveway/parking spot or leave clean newspapersdown underneath the car so you can see exactly where the leak is coming from.
3) Have a lot of light handy when looking
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I would definately check the hoses first. Actually, if they look even a little off, just replace them. They aren't that expensive and it will save you the headache later.
Also, a variation on Nutriaforbreakfast's method is to fillup your resevoir to it's proper level (also check the radiator itself-while cold- to see if there is anything visible).
Clean all effected areas.
Then, take the car for a drive (5-10 mins) to warm it up and then leave it on (parked) with the A/C on.
You should be able to see and smell the coolant/antifreeze and localize where it's coming from.
