OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Sat Nov 13, 2010 12:15 pm
I would drop by an Advance Auto Parts (or similar) and borrow their coolant system pressure tester. I'm not sure about the 94 but on my 91 there are two coolant system caps. One for the radiator and the other on the aluminum piece that Mike G. described. When I removed the plastic piece that overs the radiator top, I found the other cap. I would pressure check the system to see if you can see a slow coolant leak.
