604-Allstar »
https://forums.nicoclub.com/604-allstar-u210325.html
Wed Dec 14, 2016 11:53 am
Hi,
I recently discovered that my passenger foot well was soaking wet. I tried to soak up as much of the liquid as I could, but it didn't show any tint of yellow/green. The car does have afaint smell of coolant though. I checked the coolant level, which was low, so topped it up. The next day i came back to the car and there was a small pool of coolant under the car which had dripped from the back of the engine bay. After some searching on this forum it appears I might have a blocked heater core or a cross over tube leak...
As neither job looks very fun to do, I want to make sure that i'm tackling the correct issue.
Couple questions
1. Will a leaking crossover tube cause the passenger foot well to be soaked?
2. Can a blocked heater core cause a coolant leak on the ground?
3. If I do a pressure test on the cooling system will that help pinpoint the problem or will both cause the same results?
Thanks for any help
