dustyk »
https://forums.nicoclub.com/dustyk-u13031.html
Fri Sep 03, 2004 5:18 pm
So I noticed that my car leaves small puddles of coolant after I drive it. I looked around and saw that coolant was leaking from right at the bottom of where the water pump mates to the block. I took the water pump off, cleaned the flange off, put new RTV silicon on and bolted it back in place. It still seems to leak from right at the bottom of where the water pump bolts to the block. Is the water leaking from the Water pump? There seems to be a plug on the block (big hex drive) could it be leaking from there or is this leaking a sign that my water pump is dead? Any one have or had the same problem?
