beans33 wrote:coolant was everywhere
if coolant was everywhere something could have ruptured and sprayed coolant near the injectors causing them to pool... there really isn't any coolant lines above the injectors (or even on the upper part of the intake manifold) that could be leaking there. My guess is a hose popped and sprayed up there.
I had an under-the-manifold coolant hose spring a pin sized hole that once it heated up sprayed coolant everywhere until it finally burst on my way home afew months ago (promptly draining my coolant all over the place). Just let the car run for awhile and see if you can figure out where the leak is (if its not immediatly apparent just by looking under the hood of course). Make sure you have enough coolant in the radiator and overflow tank before you start though
Sean
