crankor »
https://forums.nicoclub.com/crankor-u316309.html
Mon Apr 14, 2025 5:16 pm
Posting an update.....
I still haven't gotten my fans in that were suppose to be here today (said they delivered them but did not) But i did find the cause of the coolant leak behind the engine atleast. One of the lines that was leading down the center behind the intake was torn in a few places and ripped apart from the nipple when i tried twisting it off. I ended up replacing it with the closet match fuel line size.
One thing that still concerns me, well i filled up the radiator and reservoir yesterday and only had the car idling with some revs for testing purposes and today when i checked, the reservoir was empty..... Not sure how that would just empty itself out and the radiator was pretty much empty too. Granted this was before i replace that hose but i cant imagine that it would have leaked from there all night when that would have had to been under pressure....So i'm a bit confused on that part.....
Anyways, i did also add the aluminum bleeder on the left side where there was just a straight plastic piece that was pretty warped,then took me a while to bleed the system. Had no heat at first and had to bleed it like 3 times.
one of the other concerns is it looked like there was always a few air bubbles coming out from the radiator when i left the cap off. That made me worry that the head gasket could be bad, BUT after the third bleed and making sure the system was full, it stayed at a steady temp during the test drive. I didn't drive it too long but it stayed where it should be. (without the fans ha) I would imagine if the head gasket was bad that it would be overheating on acceleration?
well for now my next step is to check the tank tomorrow morning and see if theres any fluid in it and depending on that result, i'll most lilkely bring it into a shop to have a leak down test done. Oh and i didn't get to change the oil yet to check for coolant mixture but from the dipstick it didn't appear to be milky at all so i'm hoping the gasket is fine. I just really don't know where else the coolant could be going over night
