coolcloo1019 »
https://forums.nicoclub.com/coolcloo1019-u3214.html
Fri Jan 09, 2004 5:26 am
well i replaced the thermostat this weekend...what a chore that turned into. I took everything off, replaced the thermostat and then i noticed coolant leaking out of the thermostat housing. I took it off again and noticed a nice crack around one of the bolt holes. So, called all around late Saturday afternoon and no one knew where to get one. Sunday morning I go to the junk yard. Alright, 3 240's there...2 with missing engines and the 3rd all it was missing was the radiator hose and the housing that I need. Great, well its time for JB Weld. Got it back together and is working good. Go out for a while and drive around...stop at the g/f's and what not then on my way home I notice the gauge is almost FULL hot then all of a sudden it goes down and stays there. Come home and get out of my car, notice water running down the driveway. Oh $hit! I look at the housing...dry as a bone. Look at the bottom of the radiator and there is coolant all over...either I didn't tighten the bottom hose tight when I put it all back together or else the radiator is cracked...$HITTY...I'm going to have to check it out in the morning. I'll keep you posted...
