i just finished replacing my tensioners/guides on my sohc hardbody and just as my luck would take me there was coolant in the oil after i started her up.. @#$@#
i only ran the engine a few minutes to warm it up, and after warming up noticed it. so i went ahead and drained the coolant out, no oil in that, and drained the milky light brown oil out too.
i assume somehow i went wrong putting the front cover on as the only place that coolant could get introduced into the oil from this job is the transfer passage from the block to the front cover right? The seal i put on looked to be decent after i took the cover apart, but it probably leaked under pressure.
the FSM says to take off the oil pan when taking the front timing cover off. anyone here do that? It seems like it's a motor pull type job to take the oil pan out for this. if you don't take the oil pan out, it is of course hard to get the front cover because the upper headgasket has to line up and the oil pan is right there on the other side.
anyone who has done this job successfully have tips? I am frustrated and need a break
