nope, only weak hoses or bad cap can do this
too much pressure can break radiator end caps and burst hoses
I don't consider hoses found at the parts stores to be good quality ones either... they're fine for a normal car, but not for performance applications... OEM hoses are better in this regard because they are built to a higher standard
if you just want to get a good cheap 1.3bar cap, get a stock mazdaspeed6 cap from a mazda dealer... it's only 20 bucks and I'm pretty sure it fits... I looked at the cap size and snout before and it looks like the nissan one... the cap won't say anything fancy of course, but it works and it's good quality... an 06 or newer RX-8 cap also fits and is also 1.3bar
but since your system is marginal right now and you're susceptible to bursting, I recommend sticking to stock or lowering to 13psi (0.9bar).. you won't have a very good boil over protection, but it'll reduce the likelihood of the system blowing out and leaking out all the water which will strand you on the side of the road
