Question is if i want to replace all the coolant lines what should I use??? Where do I get all the OEM Coolant lines because I replaced this same Coolant line without taking off the manifold with A regular hose I got from AutoZone. The ones you get by the foot. Was that wrong??? Its the line that runs from the front back then up and back to the front again. BTW its a KA24DE.
BTW. When the car ran hot and my A**hole Stock temp gauge all at once jumped straight up. So I popped the hood and my radiator was cold. but steam was coming out from behind the intake far back. SO im really not sure what happen?? Is my water pump stopped up?? cant find the bust but I checked the compression all around was 142-146 still good. After 2 overheats in 1 month.
