sicj »
https://forums.nicoclub.com/sicj-u95487.html
Wed Feb 18, 2009 8:49 am
So this is a strange problem that I can't figure out...
bought my friends 92 coupe with a DE in it. The car does not overheat, rad is full of coolant as well as the overflow.
turn the engine off after a drive, the coolant goes back into the overflow. After that there is a boiling/gurgling sound coming from the top hose and the top hose slowly gets vacuumed flat as the sound fades away. the hose is FLAT, this also sometimes happens to both the upper and lower hoses, but not always. It sometimes also happens while the car is running.
I've had the car for a week-and-a-half and this has happened since I bought it. Car has never overheated or shown signs that it was.
release the rad cap and of course everything expands back to normal.
what the hell could be causing this? it's like I have a vacuum inside the coolant system sucking the hoses down.
