sw9mm »
https://forums.nicoclub.com/sw9mm-u212498.html
Sun Dec 09, 2012 7:35 pm
thanks faja i will. If they won't change out the coolant temp sensor that will be something i'll do. its only 20 or 30 bucks and 5 min to do. the car runs good the heat works good, mechs says its good, coolant level is good. the rad hoses are good no leaks. the CTS its seperate from the ECT sensor in the block, CTS runs the gauge only. I have read that its common for them to fail on nissans
