It's VERY sufficient on a car that old , '02 ? Using the drain-cuck only , several flushes with distilled h2O , last drain simply add full strength coolant for say 60% concentration just multiply the system capacity (overflow calc is splitting hairs) by that 60% . Like a 10 quart system gets 6 quarts , or 1 1/2 gals of full strength coolant added to the "drained" radiator ,with shut drain-plug.Now when you add distilled to topoff,you got that perfect mix you want. Then you can pre-mix that 60% - enough to go into overflow , which you should of siphoned the "old" out peviously.
The word of caution comes down to , if you want to knock yourself dead locating , AND trying to loosen/remove WITHOUT BREAKING ??? Those block plugs ! If you knew the utter pandora's box your playing with , the difficulty in close quarters combat to fix that disaster. I would'nt want to be your neighbor seeing you kicking your own Azz up and down your street if you F' up
I mean hell yeah IF you can even find them , AND easy to get to , AND they loossen with "one easy twist" ,
otherwize FUGGETTABOUTTITT .
Last tip : Summer is sort-a worst time to do coolant if air bleeds and air-trapped-trouble-spots in upper motor like heads ,etc. Is another reason "most" do the pre-winter coolant thing , you know. Motor can FRY , Blow head gskets, IF not done properly and IF your in a very very hot climate especially
Gotta do what ya gotta do?
