I was wondering would it be worth installing a coolant filter such as this: http://autocoolantfilter.com/ after seeing this:
Thanks to Unknown007 (Berner)
Its a shame a Magnefine like filter won't work because it does filter down to 3 microns!
Told ya so.qship96 wrote:Those pictures are from subgenius Berners {007unknown} car, which has been permanently retired due to abuse, neglect, and stupidity.
It's now a cubic yard of metal on a slow boat to a steel mill in China.qship96 wrote:.....which has been permanently retired due to abuse, neglect, and stupidity.
Because lake water is full of leaves and fishes and twigs and frogs and seaweed and sticks and feathers and canoeists.elwesso wrote:In all fairness, in most boats there is a filter (well a screen) that filters the raw water coming into the engine..
oldmako wrote:Who takes your used coolant?
If you have particulates in your cooling system, you've already failed, and a filter won't help you.AZhitman wrote:A filter in a cooling system is a dumb idea. What happens when it clogs? And what are you trying to protect?
http://www.tefba.com wrote:
A large percentage of the overheating problems that many classic and performance car and truck drivers face are directly related to the radiator. Over time it tends to get clogged by debris, condensates and "gunk." One simple way to help prevent the restrications due to this clogging is to install an automotive coolant system filter.
