Coolant dripping from transmission/block???
simon524
Car: 93 240sx Fastback<3
So my 93 hatch is leaking coolant from where the transmission bolts up to the engine... not sure if theres a hose or plug above that which could be dripping. Has anyone else had this problem? https://www.youtube.com/watch?v=kzjb8DS8IdA
cbadsil80
Car: 1993 240sx-Ca18Det
Have you checked the heater core hoses?
from what it looks like to me that is most likely where its coming from
and is it leaking after the system is pressurized or all the time???
simon524
not exactly sure where those hoses are, and it only leaks when its pressurized
PapaSmurf2k3
Site Admin
2 possibilities - the heater core hoses that run from the intake manifold area to the firewall, or you have an externally leaking head gasket from the back side of the head, and its dripping down.
simon524
wouldnt there be smoke from the exhaust if it was the hg? there was no smoke when this happened
cbadsil80
If its a external leaking HG then there would not be coolant leaking in to the cylinders or at least enough to cause it to smoke out the exhaust
but i would way check the coolant hoses leading to the firewall(heater core lines) first
its better to start with the easy/cheaper fix first
simon524
thanks for the advice, Ill check them in the morning. Ill have to take off the intake manifold to check those lines correct?
cbadsil80
no not entirely if you pressurize the system and look around the intake manifold you should be able to see where its leaking from
but to replace the line it is recommended to take the manifold off due to it actually being easier to replace the line, yet you still can do it with the intake maifold on but i hear running the line properly is a b***h
cbadsil80
also i would recommend getting or renting a cooling system pressure tester to test the system
its easier and nicer to the motor
simon524
will do, thanks!
simon524
Thanks for the suggestions! I took of the upper half of the intake manifold and replaced all those lines that run through there. It ended up being the heater core line like you mentioned.
cbadsil80
:bigthumb: :dblthumb: Nice and good Job getting it done
My buddy had it happen to his S13 so it was my first thought
And he never wanted to do it cause it involved taking the manifold off
he ended up having a buddy do it for him
