coolant disappearing
hkssupratt1994
Car: 92 240sx hatch
after about two days of normal driving or depending on how hard i drive the car it starts to run hot and i saw that is was because the coolant was getting low so i filled it back to the top and it does fine for a while then disappears again especally if i drift it hard.the car has a new radiator and the termostat is perfect when i first got the car is was tested for a head gasket they said it was fine should i test it myself where could it be leaking.the car has not a drop under it after i drive it
hkssupratt1994
Car: 92 240sx hatch
it only happens when i drive the car hard
Chezedik
Car: 1991 Nissan 240sx
Water pump?
hkssupratt1994
Car: 92 240sx hatch
i took it off it seems fine
Chezedik
Then yes, you should check your head gasket if you cannot find the coolant leak.
hkssupratt1994
Car: 92 240sx hatch
i'll go buy a tester
