Also, what should I do regarding the CVT fluid? Should I bring it to Nissan and have them check the fluid condition with CONSULT first before doing anything? Anybody know how much that would cost? Neither maintenance schedule lists a change interval. I see the recommended procedure is to disconnect the cooler return hose and fill with new fluid at engine idle. This would take 11 quarts, which can be very expensive as I've read that the Nissan CVT fluid is $20/qt?
A couple other questions:
- At certain RPMs when accelerating there is a distinct "rattling" noise. Is this timing chain rattle, or? This happens with the Nissan OEM filter, and a Wix filter, so I'm pretty sure it's not filter related.
- Anybody had any luck with non-OEM oxygen sensors? Bank 2, Sensor 2 is bad per engine code. An OEM sensor is $151.
