AZhitman wrote:Antifreeze is, in and of itself, a corrosion inhibitor.
Most folks here (myself included) don't recommend ANY "additives" in a cooling system. For your car, the ideal mix would be:
70% distilled water
30% antifreeze (not that pre-diluted stuff)
1 bottle of Redline Water Wetter (or comparable product)
There's really no reason to use anything else.
In most climates the 70/30 will work. A mix of 40% antifreeze and 60% water provides freeze-up protection down to -10F and boil over protection up to 259°F. I was running somewhere in between 60/40 and 70/30, and I actually had my radiator freeze on me one time when it was close to -10°F.
Check out this article, pretty interesting how this works.
http://en.wikipedia.org/wiki/Ethylene_glycol
70/30 will give you better boil-over protection in the summer months, but for many, that's too much water. Just good to know.
Water wetter basically increases the heat transfer characteristics. The reason you want to run as much water as possible is because water is overall a good heat transfer fluid, where anti-freeze really isn't. The most universal recommendation would probably be 50/50 Antifreeze/water, and the water wetter.
Anyway, regarding the corrosion inhibitors, it's not really necessary on the Nissan engines. What I do is I drain and refill my coolant once a year (takes a smidge over a gallon), and that keeps things fresh.
