coolant/cooling system question
underground57
Car: '93 240sx fastback, '04 Frontier
My stock s13 KA overheated last week due to using up coolant and then getting air into the system. I filled it again and bled it and it ran fine, but I checked on the coolant again today and the resersoir was down to the minimum line. The weather's been hot lately (90's) but is this normal to be using up coolant this quick? I didn't see any leaks and the upper hose and thermostat were replaced last year. Is it time up grade to an electric fan and/or new radiator?
Axel Grungy
Car: 2001 G20 5spd
You should never use up coolant. Its either burning off or getting into your oil. Your headgasket could be toast.
da40
Car: 1995 SE 240sx
HMMM check ur head gasket might be going??????also check the tailpipe to see if ur gettig colored smoke just in case other then that id say u might have a leak somewhere if its ur rad or one of the back hoses do the old process of ilimination never fails
i2ice4m3
Car: COUNTERSTRIKE!
open up ur radiator cap and see if there's tiny black dots. Feel it and if the texture is oily then you've got a leak somewhere into your block. Either headgasket or the block is cracked somehow.
Axel Grungy
Car: 2001 G20 5spd
check your oil too and see if it looks milky
JesusLikesKFC
Car: 91 240sx, geo prizm
cracked block?
