US95S14 »
https://forums.nicoclub.com/us95s14-u2939.html
Sun Nov 17, 2002 8:58 pm
Okay, so I'm new. Not just to this forum but also to what's under my hood. As my name says I have a 95 s14 in the US. I "Flushed" the coolant in my car recently. I did this by opening the drain c*** at the base of my radiator and the cap. After everything drained I replaced the drain plug and poured one 22oz container of Valvoline Zerex Super Flush into the radiator and filled the rest with tap water. I used the super flush because the previous fluid was BLACK!? Replaced the cap and ran the car with heater on hot untill gauge registered regular temp. Let the engine cool, drained in the same manor, refilled with tap water, ran till warm again. Drained again, water came out clear. Filled the radiator with 60/40 Prestone/Water. It took under 1 gallon!? I let the car idle for a while until it overheated. After the engine cooled I took the radiator cap of to see a need to more coolant. Topped it off with the rest of my gallon. Let it idle for 15min until it overheated again. This time while cooling the top radiator hose imploded. Like placing a finger at the end of a straw and sucking the air out. What did I do wrong? I understand the s14 likes to trap air in the coolant system. What do I do now?
