If your just doing that, just remove the hard air intake pipes,move the PTU back, drain and remove the radiator and hoses, and the fan. Then remove the upper aluminum water pipe ( 3 or 4 6mm hex heads i think). You will need to reach up in there with needle nose and take the clamps off the old coolant bypass hoses. Pull the pipe out, take the old hoses and clamps off ( a total of four). Tap the new ones on and place the rear clamps on. Go ahead and put the other clamps on all the way towards the back as well. Make a seal on the coolant pipe and push on, making sure both hoses go over the pipe. Screw it down and move the second set of clamps moved to the back towards the front to hold the coolant bypass hoses on the coolant pipe. Reassemble in reverse order.
Here is a link, but not to much help with the bypass hoses, but there are some pictures to look at.
http://www.pexcom.com.au/z32cms/e107_pl ... ontent.256
