Currently my Sr20det redtop has coolant bypassed. Was wondering If these problems can be solved if i put coolant line back to the tb.
I usually cant drive the car right off the bat. Needs to warm up for few minutes But it is drivable but the response is really bad. If you press the throttle it takes about few seconds before it kicks in and it doesn't drive nice until its reaches a certain temp. The temp goes up and down a bit until it warms up.
If i add the coolant line will it run normal. Like i can start the car and move after few seconds.
Thanks guys
