bentvalves »
https://forums.nicoclub.com/bentvalves-u46428.html
Sun Aug 05, 2007 9:33 am
they are there to keep the throttle plate and PCV valve from freezing in the winter I would assume. I also read on SXOC, that because these little lines are the highest points in the cooling system, when the car is shut down air bubbles migrate upward into TB, and PCV plate and fresh coolant is pulled through your turbo.
I did away with all of it, but I can hear water boiling in my turbo after shut down. Im sure some coolant will alleviate what Im hearing though, as Im running distilled water + water wetter at the moment.
