Coolant burp
SlidnSideways
Car: 97 Nissan 240sx SE
Im about to flush and fill my coolant and heard that the KA traps air easily.
I have heard about a burp hole or bleeder valve for the coolant to eliminate the trapped air. Where would this be? I have searched and checked out the FAQ on 240sx.org
This would be for a KA24E
Thanx for the help!
--Tim--
themadscientist
never worked on a KA but the RB has a problem like that too, the highest point in the system will have a bleeder of some kind. On the RBs it's a bolt on the intake. Look at the motor and follow the hose routing to the highest point of the system and you should find something.
nissilvat
Car: 1990 240sx
on the drivers side, there a is a "plug" just below the exhaust manifold. looks similar to an oil drain plug. i belive this is what you may be searchin for
jmw19_99
Car: 1992 Nissan 240sx KA24DE
Get one of those valved radiator caps, u know, the ones with the handle on top. I grabbed one of those and just pulled the handle up while the car was running till it came up to temp. Ran it for 10 min. then shut down. Repeat when car is completely cool. Worked for me. 1
sliders
Car: DRIFTING
its on top of the intake manifold around the temp sensor. you unscrew the plug and fill up the radiator with coolant till it starts leaking fom plug then tighten. The plug under the exhaust is a block drain plug
