doridori23 wrote:Do you have access to a coolant pressure gauge? That and a dye test are the only two ways to rule out a head gasket or head/block leak.
im not sure, could i pick one up at autozone or something?
is there any other things i can look at to see whats causing this? its ****in annoying and pissin me off
a few days ago after driving for a while, i was idling and if i tapped the gas pedal real quick it would pause then rev but i tried it the next day after warming it up and it didnt do it.. what could cause that? does it have something to do with the coolant bubbling and maybe getting pretty hot?
